Skywatcher star adventurer laser finder
Re: Skywatcher star adventurer laser finder
Postby bengourben » Wed Aug 15, 2018 11:12 am
rwillits wrote:I found an adapter for my camera that operates on 12 volts. It came with a cigarette lighter end, which I cut off and replaced with a 5.5mmx2.1mm 12v female plug. I use sealed acid-lead rechargeable utility batteries that are used in children's toys, with a lead and a 5.5mm x 2.1mm male end. This is portable and will run my camera for days. These batteries with the same lead will also run my USB hub, my camera, and my mount. With a similar 12 volt adapter, I can also power my lapy (12v to Dell). I hope that this can help.
That's very interesting, Richard.
I've been looking for an alternative solution to powering my camera without mains supply.
Could you post a picture of your set-up? Is it a large battery?
Cheers.
Jason
Skywatcher 200p
Heq 5
Modified Canon 1000d
Qhy5ii mono,Finderguider
