Milky Way from Spain
For things not so close up.
Postby carastro » Fri Jun 23, 2017 1:29 pm
Well this is the first acceptable Milky Way I have done since starting imaging in 2008. Always had trouble with focus, but knowing I had a holiday in Spain coming up, I got myself an Ioptron Skytracker for travel and did a bit of of practising before I left.
Stayed with some friends who have an apartment by the beach south of Estepona. It was still rather LP as I could not see the Milky Way. There were lights from the other apartments and also lights along the beach path which I managed to block out with various items.
Carole
On 16th June I took this image with the Nifty 50 lens on a Canon 1100D and the Ioptron Skytracker 16 x 1 min subs.
Then a few days later I took another part of the Milky way, this time the Core of the galaxy, PA seemed to go well so I risked 4min exposures with same kit as above - 5 x 4mins. Image
I then attempted to make them into a mosaic. This was tricky due to the different length exposures and differing gradients and processing, I combined them manually - here is the result:Image
...and lastly an annotated version.Image
Re: Milky Way from Spain
Postby galileo » Fri Jun 23, 2017 3:19 pm
Postby carastro » Fri Jun 23, 2017 4:55 pm
Postby swag72 » Fri Jun 23, 2017 9:38 pm
swag72
Postby carastro » Fri Jun 23, 2017 11:14 pm
Postby thymelord » Sat Jun 24, 2017 3:58 am
Postby carastro » Sat Jun 24, 2017 9:27 am
Return to OBSERVING AND IMAGING: WIDEFIELD
