widefield with QHY8L
For things not so close up.
Postby jjb2011 » Tue Jun 24, 2014 11:02 pm
It has been interesting to see the great widefield shots in this section so I thought I would have a go at it. The problem is I dont have a DSLR Camera but I do have a QHY8L. To connect a typical canon lens to the camera I purchased a Geoptic adapter from Bern at Modern Astronomy he gave me a good price at the IAS.
I also needed a canon lens so a bought a low cost second hand 28-80mm F3.5-5.6 lens just to try the the combination out. Here is the camera-adapter-lens setup. The spacing required from the back of the lens mount to the chip is 45mm for the canon lens. The QHY8L has a spacing of 20mm from the chip to the front of the T thread and the Geoptic adapter is 19mm thick so a 6mm spacer is needed to get the correct spacing.I used the tilt ring which was supplied with the camera it looked to give about 4-5mm so maybe the 1-2mm remaining can be taken up by adjusting the lens focus.
Observing around the summer solstice is not easy with a one-shot colour camera but I just wanted to see if the combination works without too much viegnetting (how do you spell that ?), distortion and that the system could be brought to focus. I mounted the camera on my NEQ6 mount and set up a rough and ready polar alignment and no guiding. To my surprise the combination seems to work and here is my first QHY8L widefield image showing the constellation of Cygnus last night. This is a single sub at F3.5, 28mm and 60sec sub taken using Nebulosity3 with no further processing just for proof of principle.
Will try some more when the sky darkens later in the year
jjb
Re: widefield with QHY8L
Postby Dion » Wed Jun 25, 2014 12:41 am
Postby jjb2011 » Wed Jun 25, 2014 8:51 pm
Postby Zakalwe » Wed Jun 25, 2014 9:26 pm
Zakalwe
Postby silentrunning » Wed Jun 25, 2014 9:26 pm
silentrunning
Postby mikeobrien » Wed Oct 19, 2016 1:13 am
mikeobrien
Postby galileo » Wed Oct 19, 2016 8:34 am
Postby Dave Smith » Wed Oct 19, 2016 9:03 am
Dave Smith
Return to OBSERVING AND IMAGING: WIDEFIELD
