Precise polar alignment with alignmaster question.
For the discussion of posted tutorials so as not to break up the threads. Just start a thread here with the same name as the tutorial.
TUTORIAL DISCUSSION
Why a tutorial discussion section? Well, if a person is posting a tutorial thread in segments, the tendency is for people to post questions in-between. This causes the tutorial to become convoluted.
So, if you post a tutorial, especially if you intend it to be several messages long (ie, in steps) please also post a thread here with" <name of tutorial> discussion" as the subject.
Thanks
Postby cuivenion » Wed Mar 09, 2016 3:46 am
Hi, first off great tutorials Dion, they've really helped me in this hobby. I have a couple of questions about the above tutorial.
- How accurately do I need to be polar aligned before aligning with alignmaster? On my first attempt I had Polaris in the large polarscope circle thinking this would be enough, but the gotos to the alignment stars were just barely in the view of my widest field eyepiece (24mm 68degree max vision).
- I understand I have to do a one star alignment in eqmod in before using alignmaster. I am a little fuzzy on the procedure though. Should I?
Be set as Append To Sync, do the one star alignment.
Change to dialog mode and use Alignmaster.
Reset as Append To Sync, park to home position.
Start using eqmod.
- Once all that is done, do I need to delete the alignment points created by Alignmaster?
- Most puzzling question for last. When centering your star (in Alignmaster) in the two part section where you use AZ and ALT bolts,it implied that you can only use AZ in one section and ALT in the other. I found it in impossible to center the star using just one set of bolts, I had to both AZ and ALT in each section to get the star centered. Am I doing this right?
Sorry for the long post, any help would be great.
cuivenion
Re: Precise polar alignment with alignmaster question.
Postby Dion » Wed Mar 09, 2016 12:00 pm
Postby cuivenion » Wed Mar 09, 2016 12:16 pm
cuivenion
Postby Dion » Wed Mar 09, 2016 6:24 pm
Postby cuivenion » Thu Mar 10, 2016 2:31 am
cuivenion
Postby Freeomano » Fri Sep 23, 2016 3:38 pm
Freeomano
Postby cuivenion » Sat Dec 31, 2016 3:14 pm
cuivenion
Return to TUTORIAL DISCUSSION
