Don't forget that the clocks have gone back if you are in Britain. The board doesn't automatically do this for you as it doesn't know whether you are in Britain or not. To put your clock right on the board, do the following :-
1) At top left of board you will see "User Control Panel" click it.
2) From the window that now appears click the tab marked "Board Preferences"
3) Near the bottom, it says "Summer Time/DST is in effect:". Select 'No' then click the 'submit button at the bottom'
