DIY Tracking/Goto Controller for EQMOD
Postby TCWORLD » Thu Jan 19, 2012 11:15 pm
Evening all.
I have just started work on trying to create a DIY alternative to SyncScan that works with the EQMOD api for ASCOM. I have been doing alot of google crawling to get me started and have come across the elusive protcol that is used by the SyncScan EQ5/6 mounts.
However, I have hit a snag. I know what is sent by EQMOD and why. I also know the format of the responses required. But that is where the trail goes cold. Some of the commands require responses that are specific to the mount, and there is no information as to what the response should be.
Sooo, is there anyone out there with an EQ5 SyncScan mount, that has hooked it up to a computer?
If there is, could you please raise your hand, as you will be able to find out for me what I need.
As an incentive, if I can make this work, it will be entirely open source, and a nice cheap alternative to the very expensive SyncScan upgrade. As far as I can tell, EQMOD can do everything that SyncScan does and then some. The only problem is it requires the motor control board that comes with the SyncScan controller, which is what I am trying to create a DIY compatible version of.
Thanks,
Tom :)
TCWORLD
Re: DIY tracking for EQMOD
Postby TCWORLD » Sat Jan 21, 2012 10:04 pm
TCWORLD
Postby thymelord » Sun Jan 22, 2012 7:54 am
Postby barry » Sun Jan 22, 2012 11:47 am
barry
Postby TCWORLD » Mon Jan 23, 2012 11:22 pm
TCWORLD
Postby TCWORLD » Sat Feb 18, 2012 1:59 pm
TCWORLD
Postby Zakalwe » Sat Feb 18, 2012 2:12 pm
Zakalwe
Postby TCWORLD » Sat Feb 18, 2012 2:43 pm
TCWORLD
Postby joncarruthers » Sat Feb 18, 2012 4:27 pm
joncarruthers
Postby TCWORLD » Sat Feb 18, 2012 6:03 pm
TCWORLD
Users browsing this forum: No registered users and 4 guests
