correcting focal length-SPC900 and Large Dobs
Postby lightbridgedriver » Sun Jan 08, 2012 9:42 pm
Hi Guys,
I have had a couple of emails regarding problems making the SPC900 work with a Lightbridge telescope. seems the limit to downward travel with the standard 2" focuser adapter is prohibiting prime focus with the SPC900 I have this quick solution I have come up with that seems to work. I imagine it will work with other Dobsonian reflectors as well, although I have not tried it on the 16" version
Picture #1 is my just arrived Phillips SPC900 LX imager. Mine has the USB convertor integrated into the case, I assume others' may be the same, or a little different. But in any case, you can see a new 2" nose piece attached to the front of the imager with a cap over it.
I installed the camera and initialized it for the first time, trying both short and lond exposure settings per Dion's tutorial, and all works smoothly.
I tested a rough focus on mountains about 10 miles away from here. The picture is very bad because we have a lot of haze today, but I was able to achieve focus no problem. Now I realize this is probably not infinite focus, But I think this may still work:
The next picture is the SPC900 installed to the 2" focuser with the adapter nose piece added on. This is at focus on the mountain 10 miles away,
and if you notice, I still have almost 3/4 inches (almost 19mm) downward travel. So I believe this would still be more than enough downward travel to get objects at infinite focus...
The adapter is attached to the SPC900 via setscrew... and is a great little item to have. It has only a 1mm flange, and the 1.25" socket is recessed pretty far down there.. so even better with focal reducers and the like for other applications.
You can purchase this item here: http://www.optcorp.com/product.aspx?pid=3561
Edit: a domestic alternative to avoid high shipping charges: http://www.ebay.co.uk/itm/Blue-Fireball ... 19c7802e1c Note: you will want to remove the thumbscrew and replace it with a set screw so it will fit into the focuser tube probably the hardware store has this at a few pence.
I will test it out this week and see how it all works out. but this seems to work great
Cheers!
Last edited by lightbridgedriver on Tue Jan 10, 2012 2:38 am, edited 6 times in total.
lightbridgedriver
Re: correcting focal length-SPC900 and large dobs
Postby paraman » Sun Jan 08, 2012 10:47 pm
Postby lightbridgedriver » Sun Jan 08, 2012 11:41 pm
lightbridgedriver
Re: correcting focal length-SPC900 and Large Dobs
Postby lightbridgedriver » Tue Jan 10, 2012 9:00 pm
lightbridgedriver
Postby lightbridgedriver » Tue Jan 10, 2012 9:55 pm
lightbridgedriver
Postby Brumtaffy » Tue Jan 10, 2012 11:08 pm
Brumtaffy
Postby lightbridgedriver » Wed Jan 11, 2012 12:50 am
lightbridgedriver
