Is Skywatcher Quattro too heavy for AP on an EQ6 R?
Postby Ryan Hall » Tue May 29, 2018 7:25 pm
Hello, just looking for a bit of advice.
So I was searching for a good reflector telescope for the EQ6 R and I saw there was a lot of people on Astrobin using the Skywatcher Quattro 10CF OTA on an NEQ6 mount and they were getting some decent images, then I googled the weight of the Quattro 10 CF and it was almost 15kg which is around 80% of the mounts 18kg weight capacity, and that's without any accessories. Now, although it is under the recommended weight limit for the NEQ6, I heard that the rule for astrophotography is that you should never go above 60% of the mounts capacity, which leads me to my question:
Is it okay to put this ratio of weight on a mount and still use it for astrophotography?
And if it is not then would using the Quattro 10CF on an EQ6 R (weight capacity 20kg) or AZ EQ6 (weight capacity 25kg, not sure about how true this is though) be any better?
Thanks in advance for your suggestions.
Ryan Hall
Re: Is Skywatcher Quattro too heavy for AP on an EQ6 R?
Postby galileo » Wed May 30, 2018 6:03 pm
Postby Ryan Hall » Wed May 30, 2018 10:27 pm
Ryan Hall
Postby julianr » Thu May 31, 2018 10:37 am
Postby Ryan Hall » Thu May 31, 2018 11:00 am
Ryan Hall
Postby rwillits » Fri Jun 01, 2018 12:51 am
Postby Dion » Sun Jun 03, 2018 12:58 am
Postby craig a » Sun Jun 03, 2018 10:59 am
craig a
Users browsing this forum: Google [Bot] and 2 guests
