size of filter
For those who can't decide if there's not enough day, or not enough night!
size of filter
Postby FlikR » Sat Apr 21, 2012 12:19 am
Quick question as I am off to buy some solar filter film.
Going to get a 250mm by 250mm sheet.
Scope is the 200mm Newt and I will have to make my known filter cell to hold it. What is the best size for the filter hole??
Should I make it full aperture meaning I would use up the whole film in one go or can I still get the same results with a smaller hole for the filter film (leaving some spare in case it gets damaged). Or even using the little off axis hole on the end cap of the scope.
If full aperture makes it better than I will certainly do that. Really know nothing about solar observing so what to do it correctly from the start.
Any thoughts,
FlikR
Re: size of filter
Postby andyboy1970 » Sat Apr 21, 2012 10:00 am
andyboy1970
Re: size of filter
Postby Richard » Sat Apr 21, 2012 11:02 pm
Re: size of filter
Postby FlikR » Wed Apr 25, 2012 5:02 am
FlikR
Re: size of filter
Postby andyboy1970 » Wed Apr 25, 2012 9:09 am
andyboy1970
Re: size of filter
Postby Richard » Wed Apr 25, 2012 9:31 am
Re: size of filter
Postby FlikR » Thu Apr 26, 2012 11:10 pm
FlikR
Re: size of filter
Postby Syzygy » Fri Apr 27, 2012 9:09 am
Syzygy
Re: size of filter
Postby FlikR » Thu May 03, 2012 2:08 am
FlikR
Re: size of filter
Postby Richard » Thu May 03, 2012 12:13 pm
Return to OBSERVATION: SOLAR
