ISO - exposure - temp relation
Got a problem? Need Some help? We don't have the A Team but our users will try!
Postby AstroChris » Fri Jul 05, 2019 8:56 pm
Hi folks.
I just had a session on M27 with my dslr Olympus e510. It turned out that my subs nearly had no information above noise-level in the red channel. I then asked myself (and you)
A) what are the correlations between the variables temp/iso/exposure time.
My second question was:
B) why have i no signal above noise-level in red but signal in the G and B? Are red pixels more sensitive to temp-related iso noise?
B.1) -> are long exposed darks therefore "red"?
I searched some images and compared the three colour layers in light frames and in darks. I used only single subs and no stakked images as i want to investigate what the dslr can see.
Result 1) The rise of noise in the red channel is highly related to temp and iso is huge. At 8°C there is "little" noise in 25° there is just too much noise for signal to come "through'.
Conclusion 1) At a given temperature there is without any other helping tools no way to take images. Till now it seems that temps over 25° with iso 800 and 120sec seem like a border for my old cam. This might vary from chip to chip but for every chip there must be a border where noise rises above signal.
The red noise can be caused by light pollution or by temp-iso noise.
Result 2) indeed in the darks (taken in a dark bag at night) the red channel is more nosey than the other two channels. This indicates that the red channel is more temperature sensitive then the G and B. Red noise in the darks is caused by temp-iso-noise. Wether this is a specific chip issue or a general thing must be sorted out.
I will post some images for comparison.
Greetings
Gesendet von meinem LG-H870 mit Tapatalk
Re: ISO - exposure - temp relation
Postby AstroChris » Fri Jul 05, 2019 8:59 pm
Postby AstroChris » Fri Jul 05, 2019 9:00 pm
Postby AstroChris » Fri Jul 05, 2019 9:02 pm
Return to IMAGING: HELP
