Help with phd please
Got a problem? Need Some help? We don't have the A Team but our users will try!
Re: Help with phd please
Postby Ivor » Fri Oct 09, 2015 12:50 pm
Before going down the EQMOD route, Craig is right this should work but I wouldn't have thought the ST4 cable would cause it to crash when you press the 'loop' button as I can't see why it would be sending a signal down the cable at the point. It would be worth doing a test to rule it out, disconnect the ST4 cable from the camera and press the 'loop' button and see what happens. You might want to repeat the test with a different USB cable to rule that out as well.
The loop button is taking shots every n seconds not video like Sharpcam, you should try taking images from a capture application and see if you get the same crashing issue.
BTW What exposure time do you have set in PHD2?
Ivor
Postby Thom » Sat Oct 10, 2015 12:07 pm
Thom
Postby Silversmith » Thu Oct 22, 2015 1:02 am
Silversmith
Return to IMAGING: HELP
