Rosette in Ha and first time guiding
For discussions and posting of your deep space pics.
Postby TareqPhoto » Thu Dec 12, 2019 10:50 pm
Yesterday was cloudy, but i was in rush to test the adapters i received, and i only tested the adapter for Canon lens connection [with ZWO filter wheel], but i failed, because i thought it should be 55mm, but i found out that it must be 44mm actually, so i ended up to remove the filter wheel and place the filter on the sensor window, but vignetting is there anyway i think [or maybe that what i think].
The sky condition wasn't good, because we all know the enemy number 1 for all astrophotographers in the world, but i didn't stop, the sky was really clear if the enemy is moving away, and with the moon nearly full, and under Bortle 8/9 sky, what can you expect after all?
The only good thing from last night is that finally i managed to use guiding, so almost officially that was the first night i used guiding with, but i have to build my next plans or projects on that now, so we will see what will be next targets results.
Rosette Nebula 12 Dec 2019
Canon EF 300mm F/2.8L IS @ F/4
QHY163M + Astrodon Ha 5nm [1.25"]
Skywatcher AZ-EQ6
Ha = 7 x 300 sec [because of clouds many frames were removed, even few are still included in those 7 frames anyway :-( ], Gain 200 Offset 21 @ -10C
SGPro, PixInsight, Photoshop
TareqPhoto
Re: Rosette in Ha and first time guiding
Postby carastro » Fri Dec 13, 2019 1:23 am
Postby TareqPhoto » Fri Dec 13, 2019 2:27 am
TareqPhoto
Postby rwillits » Fri Dec 13, 2019 8:59 pm
Postby TareqPhoto » Sat Dec 14, 2019 1:29 am
TareqPhoto
Postby Pat mcevoy » Sun Dec 15, 2019 12:56 am
Pat mcevoy
Postby TareqPhoto » Sun Dec 15, 2019 6:42 am
TareqPhoto
Postby Apophis » Sun Dec 15, 2019 8:21 am
Apophis
Postby TareqPhoto » Sun Dec 15, 2019 9:42 am
TareqPhoto
Postby bengourben » Thu Dec 19, 2019 10:46 pm
Return to IMAGING: DEEP SPACE
Users browsing this forum: Google [Bot] and 2 guests
