Which filter to use for seeing/detail with a QHY5 color cam
Postby althecoal » Wed Aug 03, 2016 10:09 pm
Have been using the QHY5 color cam with my cpc11 with a lot of success but after searching the net a lot of people are now using very different filters to combat when poor seeing (quite often in UK) and to get that fine detail (the banding of jupiter for example),
There are so many to choose from , cut filters/pass filters/narrow band filters/IR-cut filters/contrast filters etc to name but a few ,,a lot don't work with the color cams and some do , has anyone had any luck with combating poor seeing and fine detail if so which filter do you use please?
althecoal
Re: Which filter to use for seeing/detail with a QHY5 color
Postby Neil Phillips » Thu Oct 06, 2016 2:25 pm
Neil Phillips
