Moon Mosaic - problems with brightness differences
Postby AstroChris » Mon Nov 25, 2019 11:03 pm
Hey folks!
Last week I took a mosaic of the moon using a 3x Barlow, a ZWO ASI120mm mini mono on my 150/750mm Newtonian.
It was bitterly cold and when i finished the session and lost two fingers to the coldness I went inside.
Next days then processing: Autostakkert and Registax. I didn't touch the settings from image to image to keep the image even and same. So the thinking.
It turned out that (even though I like the result very much) some parts of the image have brightness differences. That might be due to thin clouds or seeing our stuff. So adjusting the brightness from sub-image to sub-image is just a pain in the ***. Every time i am happy with two neighbors and then keep that brightness, three sub-images left there is a difference again. If I then align that brightness, there is a difference to the images adjusted beforehand.... And so on and so on.
The image:
Link to bigger version:
https://catchingphotons.de/wp-content/uploads/2019/11/2019-11-10-Moon_Mosaik_extrasharp_and_bright_WEB.jpeg
Q: is there a short cut? Some trick? Anything like a brightness normalisation in Autostakkert or stuff? That would be great.
I one did a mosaic without Barlow lens and it turned out just great! The overall time of that acquisition was much shorter back then. This time it took a while so seeing/clouds had their chance.
Any suggestions are welcome :-)
Thanks and greetings
Gesendet von meinem LG-H870 mit Tapatalk
Re: Moon Mosaic - problems with brightness differences
Postby Bizibilder » Tue Nov 26, 2019 7:41 pm
Bizibilder
Postby AstroChris » Wed Nov 27, 2019 6:44 pm
Postby AstroChris » Mon Jan 27, 2020 6:59 am
Postby carastro » Mon Jan 27, 2020 12:02 pm
Postby Bizibilder » Mon Jan 27, 2020 6:50 pm
Bizibilder
Postby AstroChris » Sun Feb 02, 2020 8:04 am
Users browsing this forum: Google [Bot] and 2 guests
