Combining 2 different exposures using layer mask
Postby martin_h » Sat Dec 03, 2011 4:30 pm
A classic example is M42 which has a huge dynamic range, it is hard to controll the core and process the feint stuff at the same time.
What we need is 2 different images and then blend them together to make a composite image. The usual way to do this is to make a set of exposures to highlight the outer bits, so say you capture the subs in 10 min lengths, and then go on to take a set of 3 min subs for the core.
No sound on this im afraid (no mic on the comp) ;)
The text version can be found here...... http://www.astropix.com/HTML/J_DIGIT/LAYMASK.HTM
Re: Combining 2 different exposures using layer mask
Postby martin_h » Sat Dec 03, 2011 5:19 pm
Postby martin_h » Sat Feb 25, 2012 4:29 pm
