Re-positioning polarscope reticule
Postby worcspaul » Wed Sep 28, 2011 8:44 am
When I first got my EQ5 earlier this year I noticed the position of the polaris indicator in the reticule was such that for it to be at the correct position for polaris transit the counterweight bar would have to be vertically UP. Whilst fitting replacing the adjusting grub screws with thumbscrews (see Polarscope Reticule centering and mods ) I thought I'd take the opportunity to re-position the reticule. This work is probably best done on a clear flat surface with the mount removed from its tripod and counterweight bar removed:
  • Unscrew and completely remove the lens from the rear of the polarscope
  • Holding a soft (microfibre for preference) cloth over the rear of the polarscope, loosen the three grubscrews and then carefully tilt the mount back so the reticule drops into the cloth.
  • Place the reticule on a clean sheet if paper and put a marker on the metal ring to indicate where the polaris circle is. I used a pointer cut from a sticky label. A spot of tippex (dries quicker than paint) would probably suffice :
(This is to make it easier to position the reticule when placed back in the polarscope)
  • Make sure the mount is in the HOME position
  • Taking care not to drop the reticule or get fingerprints on it (been there, done that :sad: ), tilt the mount forward and replace the reticule in the polarscope with the marker at the top.
  • Re-insert the three grubscrews and slowly adjust each one a half turn at a time until the reticule is just held by them
  • If the marker is n't quite at the top, loosen the grub screws a fraction and use a cocktail stick or similar to rotate the reticule (there are a couple of slots in the inner ring of the reticule.
  • Your polarscope reticule should now be in the correct position:
In this image you'll see the three grubscrews have been replace by M3x10 thumbscrews which make life a LOT easier!
  • Finally, replace the lens (fitting an O-ring if you choose to do so, following Dion's tutorial) and screw back in until at the desired focus point
worcspaul
Re: Re-positioning polarscope reticule
Postby worcspaul » Thu Sep 29, 2011 7:36 am
worcspaul
Postby guyroch » Mon Oct 17, 2011 1:30 pm
guyroch
Postby Shorty73 » Mon Oct 17, 2011 4:45 pm
Shorty73
Postby worcspaul » Mon Oct 17, 2011 10:30 pm
worcspaul
Postby worcspaul » Tue Oct 18, 2011 9:09 am
worcspaul
Postby themos » Fri Oct 21, 2011 12:23 pm
themos
Postby worcspaul » Fri Oct 21, 2011 3:28 pm
worcspaul
