Accurately setting HOME on an EQ5 mount
Postby worcspaul » Tue Jun 14, 2011 2:01 pm
After watching Part I of the Complete Setup A to Z I set to thinking about how the HOME/Parked position could accurately be set on an EQ5 mount (seeing as the setting circles are nigh-on useless for the task). Using Dion's tutorial as inspiration, I put together a procedure which I've now published on my blog:
How to accurately set HOME on an EQ5
worcspaul
Re: Accurately setting HOME on an EQ5 mount
Postby whatablanker » Fri Jan 06, 2012 2:46 pm
whatablanker
