New PixInsight Tutorial on Preparing a Mosaic
Postby Gib007 » Tue Jan 05, 2016 4:05 am
Read here: http://www.lightvortexastronomy.com/tutorial-preparing-a-mosaic.html
This new tutorial goes over the procedure to produce a seamless mosaic image in PixInsight. It starts off using StarAlignment to produce a rough mosaic to register the individual images with. Afterwards, it moves on to using GradientMergeMosaic to produce a seamless end result. Settings to reduce seams and pinched stars are discussed, as well as a PixelMath technique to fix pinched stars.
