by Gib007 » Tue Jan 05, 2016 4:05 am
Read here: http://www.lightvortexastronomy.com/tutorial-preparing-a-mosaic.htmlThis new tutorial goes over the procedure to produce a seamless mosaic image in
PixInsight. It starts off using
StarAlignment to produce a rough mosaic to register the individual images with. Afterwards, it moves on to using
GradientMergeMosaic to produce a seamless end result. Settings to reduce seams and pinched stars are discussed, as well as a
PixelMath technique to fix pinched stars.
- Protostar
