New Tutorial: PixInsight Workflow for LRGB (Small Targets)
Postby Gib007 » Wed Sep 03, 2014 5:13 pm
Read here: http://lightvortexastronomy.blogspot.com/2014/09/tutorial-post-processing-example.html
This new tutorial workflow for PixInsight is another post-processing example, this time of the Eastern Veil Nebula. It is based on LRGB. One of the unique features of this tutorial is that much of the image space is occupied by background and thousands upon thousands of small stars. Due to these two features, rather than crop, we exercise caution when it comes to noise reduction in order to avoid over-doing it. This is in line with the general recommendation that it is generally better to leave some noise present instead of trying to eliminate it completely (for a better end result). Moreover, since so many stars can over-power faint, diffuse nebulosity, we perform a star size reduction procedure in order to reduce the star sizes across the whole image and increase contrast on the nebulosity. Credit for the specifics of this procedure go to Rogelio Bernal Andreo (credited in tutorial as well).
Re: New Tutorial: PixInsight Workflow for LRGB (Small Target
Postby julianr » Tue Sep 09, 2014 1:27 am
Postby ribuck » Sun Jan 04, 2015 2:09 am
ribuck
Users browsing this forum: No registered users and 4 guests
