Philips SPC900NC Cooling
Postby Hutchyweb » Tue May 13, 2014 9:16 am
This mod is also available on my blog
Parts Required
Philips SPC900NC WebCam
Astro WebCam nose piece
Project Box (60mm x 40mm x 80mm)
3x 12mm M2 bolts
1x M2 Nut
1x M2 Washer
1x Toggle Switch
40mm 5v Fan
40mm Finger Guard
Modification Process
1. Remove focuser or nose piece from the WebCam
2. Remove the side covers of the WebCam - these are only stuck on.
3. Using a small screw driver push in the two clips on each side and open up the case
Image Image
4. Now do the same for the grey insert
Image Image
5. Disconnect the internal USB cable to remove the front part of the camera (Imaging boards)
6. Remove the two small screws (top and bottom of this image)
7. Now remove the two outer screws so you can separate the boards
8. Here I have tested an M2 bolt to ensure the thread is the same
9. Separate the boards
10. With in the back part of the case twist the USB cable 90° and remove through the hole
11. Mark the project box where you want to mount the fan - I've used the lid
12. Drill a pilot hole for the fan and drill 4 2.5mm hols for mounting the fan
13. Using a hole cutter cut a 38mm hole for the fan aperture
14. Mount the fan and fan guard
15. Drill a pilot hole for the WebCam lens mount bracket to go through
16. Next drill the hole for the lens mount bracket
Image Image
17. Drill some vent holes to allow the air to escape, also drill holes for the switch, USB cable and 3 holes for mounting the WebCam boards
Note: I have drilled the vents at the opposite end to the fan but the same end as the WebCam thus forcing the air to pass over the imaging chips rather than just out the holes.
Image Image
18. Install the switch and bottom webcam board
19. Connect up and solder the 5v Fan to the switch and the first and last pin of the USB connector (5v power)
20. Mount the top board on the bottom and connect the USB cable
Image Image
21. Close and screw on the lid and your finished.
Image Image Image
END OF PROCESS
Hutchyweb
Re: Philips SPC900NC Cooling
Postby Zakalwe » Tue May 13, 2014 10:17 am
Zakalwe
Postby Dion » Tue May 13, 2014 3:43 pm
Postby wayland » Fri Apr 10, 2015 5:25 pm
wayland
