by Gib007 » Wed Mar 13, 2013 11:02 pm
Read here: http://lightvortexastronomy.blogspot.com/2013/03/tutorial-nebulae-pixinsight-guide-for.htmlThe guide is not as extensive as my workflow tutorials and it's not meant to be. This guide only guides you on various ways you can combine your Hydrogen-Alpha and Oxygen-III (commonly the case) narrowband images into Bicolour Palette images, all in PixInsight. For more extensive instructions you can see my workflow tutorials but this guide can essentially produce the colour image for your post-processing.
Discussion:
viewtopic.php?f=42&t=15765Hi, you are viewing as a guest, You can only see this first post in this topic. if you sign up you get access to other goodies you can't even see as a guest, including video tutorials on imaging and processing, scope modifications and even member discounts on gear!
- Protostar
