Trust Primo PolarCam
Postby ASJ » Sat Feb 02, 2013 2:08 pm
After an afternoon session of tinkering, with better than expected results I thought I would write this one up into a tutorial should anyone want to have a go at making a Polarcam with a cheap alternative to the Philips SPC900 or Microsoft Lifecam.
This one is based on the Trust Primo Webcam, Admittedly not as good as the Philips or Lifecam and only has a resolution of 640 x 480, but coming in at around £8 I think its limited spec will be ok for polar aligning.
The actual tutorial is attached in PDF, comments can be made using the Thread in the discussion section.
Enjoy!
CLICK To Download
Link to discussion: viewtopic.php?f=42&t=14987
ASJ
