ASTRONOMY ABBREVIATIONS
Postby Dion » Tue Jan 24, 2012 12:33 pm
This was suggested by another member and it's a good idea, this will be a list of astronomy abbreviations, I'll start it off, anyone else feel free to add more and as it progresses, either I or a mod will copy/paste any additions into this post until we have one long list, and then probably alphabetize it as well, please add yours in the same format as above so it's easier to copy/paste into a single document.so :-
0111= Oxygen111 (filter)
AP = Astro Photography
Apo = Apochromatic refractor
Bahtinov = A patterned 'mask' that is put in front of scope to assist in achieving perfect focus (removed when focused), named after inventor Pavel Bahtinov.
Bayer Mask = Coloured filters infront of camera pixels to give coloured image.
Bins = Binoculars
BRB = An Aardvarkism for Be Right Back
CCD = charged coupled-device (type of sensor used in imaging cameras)
CME = Coronal Massive Ejection, outburst from increased solar activity responsible for the aurorae
CMOS = complementary metal–oxide–semiconductor (type of sensor used in imaging cameras)
Dec = Declination
Deconvolution = a process used in image processing to help reverse the effects of optical distortion.
Differential Flexture = The result of one part of a telescope system being rigid and another moving slightly in relation to it, very noticable when applied to guiding during imaging.
DOB = Dobsonian Telescope
DSO = Deep Space Object
DSS= Deep Sky Stacker
Eclipic = An imaginary line that the Sun and planets seem to take as they move across the sky.
EP = Eye Piece
ER = Eye Relief
FMC = Fully Multi Coated
FOV = Field of View
GEM = German Equatorial Mount (also known as EQ mount)
Ha = Hydrogen alpha ( filter)
Hartmann Mask = alternative focusing tool, like a Bahtinov Mask
HDR = High Dynamic Range
Hubble Colours = Artificially coloured image using Ha S2 and O111 Filters instead of RGB
Hz = Frequency in cycles per second or Hertz, or it could mean Habitable Zone - that region around a star where planetery orbits allow surface temperature compatible with life as we know it !
ISS = International Space Station
LGM = Little Grey (or Green) Men
LP = Light Pollution
LRGB = Luminance, Red, Green, Blue
Mak or MCT = Maksutov-Cassegrain Telescope
Meridian = An imaginary line that runs from due north to south.
Meridian Flip = A defined point for the limits of east or west side viewing where in order to prevent damage to the equipment caused by hitting the pier or tripod the mount is stopped and its direction is reversed, effectively the mount moves so the telescope and weights are now opposite side to where they were.
MN = Maksutov Newtonian
Mono = Black and white image or camera
Mr Blobby = The Moon (Shed colloquial talk)
NGC = New General Catologue (Deep sky chart)
OAG = Off Axis Guiding
OSC = One Shot Colour (camera)
OTA = Optical Tube Assembly
P.E.C. = Periodic Error Correction done by the mounts compter program "learing the frequency of the error and then correcting the drive motion.
Periodic Error = A repeating error caused by imperfections in mounts worm drive gear.
PI = Pixinsight
PN = Planetary Nebula
PS = Photoshop
PST = Personal Solar Telescope
RA = Right Ascension
RCT = Ritchey Chretien Telescope
RDF = Red Dot Finder is a zero magnification device that superimposes a small dot on a glass plate in line with the optical axis of the telescope and is used to align a telescope with its target.
RGB = Red, Green, Blue
S2 = (filter)
SCT = Schmidt–Cassegrain Telescope
UFO = Chinese Lantern/Venus/Sirius/oncoming aircraft - almost certainly NOT an alien spacecraft!
UT = Universal Time
Re: ASTRONOMY ABBREVIATIONS
Postby jjb2011 » Fri Jan 27, 2012 1:35 pm
Postby Brumtaffy » Fri Jan 27, 2012 2:33 pm
Brumtaffy
Postby jjb2011 » Fri Jan 27, 2012 3:45 pm
Postby jjb2011 » Sat Jan 28, 2012 11:45 pm
Postby worcspaul » Sun Jan 29, 2012 10:24 am
worcspaul
Postby Mads » Wed Feb 01, 2012 2:54 pm
Mads
Location: 234 metres above sea level, somewhere near Oldham :-)
Postby idbvideo » Sun Feb 12, 2012 1:29 pm
idbvideo
Postby pkrallis » Sun Feb 26, 2012 3:02 am
pkrallis
Postby Aussiedave » Tue Mar 13, 2012 3:26 am
Aussiedave
