Total Eclipse
Total Eclipse
Postby Jackamus » Sun Sep 16, 2018 9:12 am
The following quotation was taken from this link https://sciencing.com/darkest-portion-m ... -3210.html
'Solar eclipses are so spectacular on Earth because the apparent sizes of the moon and sun are the same. This is a happy coincidence -- the sun is 400 times larger than the moon and just happens to be 400 times farther away. Because the sun is so much larger than the moon, however, the moon's shadow appears much smaller on Earth that the moon itself. That's because sunlight is impinging at an angle from the much larger disk of the sun. The umbra forms a cone that narrows to a width of 100 miles by the time it reaches Earth'
We are told that because sun is 93 million miles away that the sun's rays can be considered parallel. If this is the case then why, in the quote above, does it say the moon's shadow is only about 100 miles when the moon's diameter, we are told, is 2,159 miles?
According to the quote above there is an angle between the sun's diameter and the moon's diameter because the sun is much larger! Something is wrong here.
Jackamus
Re: Total Eclipse
Postby galileo » Sun Sep 16, 2018 12:07 pm
Re: Total Eclipse
Postby Jackamus » Sun Sep 16, 2018 3:57 pm
Jackamus
Re: Total Eclipse
Postby galileo » Mon Sep 17, 2018 1:46 pm
Re: Total Eclipse
Postby Jackamus » Mon Sep 17, 2018 10:09 pm
Jackamus
Re: Total Eclipse
Postby galileo » Tue Sep 18, 2018 6:20 pm
Re: Total Eclipse
Postby galileo » Wed Sep 19, 2018 11:52 am
Re: Total Eclipse
Postby galileo » Thu Oct 18, 2018 9:10 am
Re: Total Eclipse
Postby galileo » Sat Nov 10, 2018 6:36 pm
Re: Total Eclipse
Postby galileo » Tue Apr 09, 2019 8:48 pm
Users browsing this forum: Bing [Bot] and 4 guests
